Showing results for tags 'power supply'.
More search options
    • Tools, Research, Reviews and Safety
    • The Classified, Swap and Sale
    • Patriot Woodworker Member Meetings
    • Network Tutorials
  • The Patriot Woodworkers Archived Forum
  • Old Hand Tools
  • New Hand Tools
  • Freedom Caps
  • T-Shirts
Marker Groups
Joined
Group
First Name
Last Name
My Location
My Woodworking Interests
My skill level is
Website URL
Favorite Quote
AIM
MSN
ICQ
Yahoo
Jabber
Skype
Facebook URL
Twitter Feed URL
My Clubs and Organizations
  1. In my shop I use 30 watt LED fog lamps I found online for spotlights at my equipment. Only issue is they are 12 volts. Enter having a 12 volt computer power supply and adding power outlets to it. Now you can run 4 lights at 12 volts. This makes #3 so far. Recently moved my drill press across shop and had no power supply outlet on that particular side. Decided now was a good time to upgrade the old one. It ran a roll up shade I use a old power window motor to roll up and down as well as a mixer out of another power window motor. Other than that it sat idle. Still runs everything just added the 4 outlets and made a new box to accommodate the inner workings better. Used some aluminum from our old shop doors at work and cut with a multitool. Drilled as needed and recessed the outlet side into the box. Thanks @Larry Buskirk for his computer box post. Inspired me to make this much better looking as well as some ideas for how to lay it out. Enjoy and be inspired. Internal wiring during fitting / testing. Bench testing with light
