Popular Post kmealy Posted June 14, 2023 Popular Post Report Posted June 14, 2023 (edited) Got one of a set of nesting tables from a friend that had a leg broken off. Process of repair: Take off one end of legs with the damage Work apart the joint on the other end since the dowel pins were at right angles Find broken off pieces and glue and clamped them back on Removed broken off dowel pin. Cleaned out holes Filled remaining missing piece with stick epoxy, let cure a few minutes then chisel and sand down to flush Glued in new dowel pin and reglued the rest Lighty sand top Apply a bit of touch up marker where needed Apply a couple coats of shellac, then a coat of lacquer Before Putty with overfill Putty after sanding Glue up Back together Edited June 14, 2023 by kmealy Cal, Gerald, Fred W. Hargis Jr and 2 others 3 2 Quote
John Morris Posted June 14, 2023 Report Posted June 14, 2023 Outstanding Keith, now that is professional! Cal 1 Quote
