Rate this topic
I know there are 2 different type of bench grinders. High speed and low speed. Plus jigs to get the correct angles. Are you able to sharpen on a high speed bench grinder too?
Share this post
Link to post
Share on other sites
Keep a container (ex: plastic butter tub) of water near by. Dip the tip of the tool into it about every pass over the wheel. It will help keep the metal cool.
Share this post
Link to post
If you use CBN wheels the thoughts now are that it does not make a =difference. A light touch is best when sharpening as unlike reshaping you are only removing a small amount of metal . Cooling with water I will have to disagree with Lew on this as with HSS which most modern steels for turning are that or better and cooling is not needed , even if the steel turns blue the temper is not affected.
Share this post
Link to post
Thanks guys for the posts - It's always to learn from the "experts" and the Old School folks
Share this post
Link to post
I cool any steel while reshaping because sometimes it gets too hot to hold.  For touching up a dull edge I see no need to cool it.  I can get it hotter using it.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
About us
Get in touch
Follow us
Recent tweets
Visit us on Facebook
