Come see our annual Adopt a Gold Star Family for Christmas Project in partnership with Operation Ward 57. We have been chosen to support this mother and her two children. How can you help? Click on the proceeding link, and see our official project page where you can learn how to participate in our raffle and how you can win some fantastic prizes! Attention on Deck!!! Uncle Sam Wants You!!!!
Rate this topic
I frequently have a reason to drill hard rock. I have never succeeded.
I have a half inch milwaukee rotary style hammer drill.  Is there a bit I can use to drill rock for fastening screws? 3/16 size holes.
I'm told the drill I have is insufficient that I need a hilti style hammer drill. but I don't have a Hilti.
Edited by Ron Dudelston
Added tags
Share this post
Link to post
Share on other sites
I see they make both drills and drill bits. Can't imagine one type of hammer drill can be that much different than another except maybe for the "horse power". Their bits have carbide brazed tips. Maybe that's the difference. I've drilled some pretty old, hard concrete with Big Box bits. Took a while and wore out the bit. Lots of stone in the mixture. I was using about the same size bits (1/4").
Share this post
Link to post
for stone...
use better made bits and coolant...
Share this post
Link to post
'Way back when, we used 1" star bits and a 3 1/2 lb. hammer to drill into granite. It took about 4 hours to get the hole deep enough, but when the fuse burnt down, it was all worth it! :wacko:
John
Share this post
Link to post
since you didn't say where the rock is or what you were drilling less try cover most everything...
FWIW.. I live on one massive rock... granite and more granite... everywhere more granite... the granite has granite..
as for bits, USA, German, Swiss, Austrian, Canadian, New Zealand...
VOE says they cost less than chinese bits..
I think the brazing on the chinese bits leaves a lot to be desired,,
I also think their carbide is too soft and detest being used in a hammer drill and do not take kindly to heat at all...
also make sure the bit is hammer drill/percussion and stone rated...
make  up something like this for flats... works premium for drilling granite counter tops...
mold  plumber’s putty around the cap, that will hold it in place AND it will to form a dam around the cap.....
partially fill the bottle cap with oil/coolant/tapping fluid...
drill through the cap...
as you drill cycle the drilling... drill a little bit, raise the bit  for a bit and repeat this cycle as often as required in 5~10 second cycles...
if you are through drilling have something to catch the coolant when the bit breaks through be it a cup or a towel...
towels are cool when the bit grabs it... this is something to think about...
for wall drilling...
put a towel under where you are drilling to catch liquids and slurry... have somebody apply your coolant w/ a spray bottle in stream mode...
no need to flood the drilling here just keep up a supply of coolant...
inverted drilling....
cycle drill dry....
outdoors and a mess isn't an issue...
run a flow of water from a garden hose to the hole...
Edited by Stick486
Share this post
Link to post
John
core bits and a demo class hammer drill will give you more holes faster which means more fuses...
we gonna do this..
we're gonna make it worth it....
Share this post
Link to post
NOTE:
if you use oil you need to clean up like right away...
use brake cleaner and then dish soap w/ a lot of scrubbing action...
you don't want the oil soaking into the stone's pores and staining it....
that just may not be the look you are looking for...
Share this post
Link to post
Yah   context sometimes is as  important as everything else.  My house foundation is made up of mortared stone about 2 or 3 feet thick.  When a joint isn't convenient as in almost any Cartesian lay out  or the joints are not drillable because they are not flat like a  brick masonry joint I end up faded with less than optimal options.  Drilling into those honkin' hard stones, many the size of my torso would be a nicer option.
Share this post
Link to post
oh they are very  very different. The energy delivered to the impact is   enormously different. That's why a Hilti is so expend-o-licious.   The  cheap hammer drill   hasn't got a genuine  hammering action it's more like a rumple disk.
Share this post
Link to post
I'm real partial to the Bosch Bulldog in SDS+, one inch and larger...
I have Hilti... I like the the Bosch way better...
but their (Bosch) pistol grip style is a waste of money..
entry level...
Factory Reconditioned Bosch RH228VC-RT 1 in. SDS-Plus Bulldog Rotary Hammer
now we're getting serious...
Factory Reconditioned Bosch RH432VCQ-RT 1-1/4 in. SDS-Plus Quick-Change Rotary Hammer
Edited by Stick486
Share this post
Link to post
yur in luck...
constant fine low pressure water jet/stream for lube... not spray..
garden sprayer works for this really well...
on horizontal, an easy simple water flow/bath is the ticket...
need mess control... use a wet vac to keep the overflow in check... or use the dam...
we bore/drill 5/32~ 5'' w/ hammer drills... after that to 24'' is serious core or rock drills...
Share this post
Link to post
I may have to get one.
EDIT: GOT ONE  from that link every one is out of stock but that reseller thanks
And sourcing better drills hasn't fallen in my  lap yet.  It won't be the BORG I can tell ya that.
Edited by Cliff
Share this post
Link to post
see Alfa Tools
Their catalog...
you get what you want from your specified country of manufacture...
another company to talk to...                      this one is finest kind..
you get what you want from your specified country of manufacture too/also and the sales reps really know their stuff and aren't on commission.....
their catalog...
I really like both companies and they get a lot of my business...
Travers has fair prices and outstanding CS/TS... very good place to go to even if you don't have a clue as to what you want/need..
they have a whole department of problem solvers...
Lowes carries some Bosch bits/tooling made in Europe...
same for HD..
stay away from -
DeWalt..
Hitachi..
Tapcon..
Chinese..
Irwin..
Makita..
Morris.. (iffy)...
some more to consider...
15GENSec.F.pdf
Driltec_23_2013_catalog.pdf
ROCKHARD.pdf
Share this post
Link to post
which one did you get???
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
About us
Get in touch
Follow us
Recent tweets
Visit us on Facebook
