Danl
Garbage Disposal
Rate this topic
After 8 years our Insinkerator Badger 5 chewed it's last morsel. We replaced it with the Insinkerator pro series. 7/8 hp and really quiet. Our local plumber bought it and installed for less than Amazon charges for the unit alone.
Share this post
Link to post
Share on other sites
We don't have one but I've replaced them for other folks. I'd look for quiet, make sure there's room enough under the sink and a port for a dishwasher- if there is one.
Usually when I ask people which one they want, the answer is "the cheapest one". Not sure that's the best alternative.
Share this post
Link to post
Like tools, cheap appliances will always bite you in the end...so to speak.
Share this post
Link to post
Look at the ratings and they pretty much say it all on which one is the best. I had a GE years ago that was guaranteed to grind glass, never tried it out on glass but it did a good job on spoons and forks.
Herb
Share this post
Link to post
Share this post
Link to post
Just a note here. If you are on a public sewer system the garbage disposal is great. If you're on a septic system,  a garbage disposal is not recommended, unless you have a grease trap installed. The grease from the garbage will clog a septic system
Share this post
Link to post
Another Insinkerator fan here, I wouldn't buy any other brand.
Share this post
Link to post
Thanks for all of the good advise.  We are on a public system.  Our disposal is not used much.  The current one is a Kenmore 3/4 hp unit installed 20 yr ago, is working fine, but is very noisy.  We are replacing the sink, so I though we might replace the disposal also.  Thanks again.
Danl
Share this post
Link to post
I'm of the opinion disposals should not be used.  It is not good for your pipes.  Plenty of water is needed to wash away the debris while and for a short period after use.  I think it is hard on the waste treatment plants too.
Share this post
Link to post
run a lot of ice through it..
that trick is excellent cleaning trick...
Share this post
Link to post
We do that all the time, and after the ice, we through in half a lemon with peel. We have a lemon tree, they are always available on the ground.
Share this post
Link to post
8 minutes ago, Dadio said:
You mean I shouldn't clean my fish and flush all the heads,tails and guts down the disposal?
Herb
No, no, no, Herb- put them on the garden! Your tomatoes will look like red basketballs!
Share this post
Link to post
Herb
no...
turn 'em into plant food...
Share this post
Link to post
17 hours ago, Stick486 said:
no...
Stick I tried that years ago and every critter from a mile around was digging holes in the garden at night.
Herb
Share this post
Link to post
a grease trap is a good idea on any septic system even without a disposal too. They are a dread to clean out though VOE.
Herb
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
About us
Get in touch
Follow us
Recent tweets
Visit us on Facebook
