Ron Altier
Glue clamp question
Rate this topic
When glueing, do you use anything to keep glue off the clamps?  Can I use a spray, like Pam cooking spray or dry teflon spray? What about using a bar of soap? I don't want anything  that will penetrate the wood. I've heard that some use wax paper, but I think that would be bothersome.
Edited by Ron Dudelston
tags added
Share this post
Link to post
Share on other sites
I put Johnson's Paste Wax on mine every once and a while.
Share this post
Link to post
Depending on what I am glueing, I use wax paper (yes it can be bothersome sometimes) or I clean them up right after I take them off. The glue usually isn't to bad then.
Share this post
Link to post
saran wrap, wax, packaging tape, wax paper but never pam. silicome or teflon...
those last three can really screw up a finish..
Share this post
Link to post
47 minutes ago, lew said:
What Kelly and Stick said.
Besides my fingers and t-shirt, what Lew said:P
Share this post
Link to post
On the clamp pads which are mostly non- stick material, I don't put anything on them. But on the rails and bars, especially on the big Bessey and Jorgeson Parallel clamps I cover them with clear packing tape. That way when the glue squeeze out drips on the rails and bars after clamping I just peel off the tape and toss it in the trash. The same goes for my smaller F style clamps.
Share this post
Link to post
use less glue..
less squeeze out..
less mess...
Share this post
Link to post
I'm on the wax paper bandwagon.
Share this post
Link to post
Another wax paper guy hee, although it's called "dry wax" and its the sheet stuff restaurants use (I guess, I get it at Sam's club). To call it bothersome is a bit of an understatement, but it's less bothersome than cleaning glue of clamp bars.
Share this post
Link to post
2 hours ago, Nickp said:
Glue stains look cool...very "woodshop'ish"... :)
SNORK!!
Share this post
Link to post
I'm with Allen on this one -- I don't use anything.  If I'm edge gluing, I put the planks on some cleats that I've put packing tape on to keep them from adhering to the work.  They keep the clamps away from the surface and thus avoid black spots due to iron+tannin+water.  And i have become accustomed to the right amount of glue to just get a few beads squeeze-out at the joint.
Share this post
Link to post
I cleaned mine up and smoothed with 0000 steel wool and used Johnson's paste wax. I'll have to check it out. I generally just scrape it off after drying. I'm usually wanting to go ahead and work on my project.......than clean it off before it dries.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
About us
Get in touch
Follow us
Recent tweets
Visit us on Facebook
