Rate this topic
5 posts in this topic
The more you cut, the more chips and dust you generate.
When a router is used, there is often a fan in the router that blows down while it is cutting.  That breeze will blow chips away from the cut with enough force to keep them from being sucked up by a brush perimeter shop vac collector in place.
I honestly haven't found a way to get "perfect" collection of the debris generated while the CNC is cutting.  If I know I'll have to suck/sweep some up after a cut, then it is less damage to my ears to NOT use a shop vac and simply let the chips fly.
The "other" thing most jobs produce is very fine dust that wafts through the air and will end up on everything in the shop.  To keep this out of my lungs I mount a filtered air cleaner right above the CNC beds in our furniture design shop.  When the wood being cut is making more dust than chips I also wear a dust mask.
4D
p_toad and MEBCWD like this
Share this post
Link to post
Share on other sites
Is it possible to enclose a CNC machine? Could we build a plexiglass box that would enclose the machine, with vent holes, and a dust collection hose attached to the enclosure, to pull air though the vents creating a cross flow of air and pulling the dust into the collection?
Understand, I am very new to CNC, so if my suggestion is completely nonsense, sorry!:)
Chips N Dust and MEBCWD like this
Share this post
Link to post
Sure John,  but the larger your CNC is the harder that will be.    I've seen many CNC Sharks enclosed just the way you describe.  If you had  a Comet or the smaller V90 MK2 from Probotix it would be reasonable.   You have to remember to keep access to the bed easy to accomplish though.   Routers/spindles generate heat as they run
(thus internal fans or water cooling) and so your ventilation will also be about removing heat.  Stepper motors also run warm.  The controller and PC will also generate heat so best to keep them out of any box you make to surround the CNC.
4D
Share this post
Link to post
That pesky little engineering block wall called heat eh? Seems like heat is always popping up all over the place while designing moving parts. Makes total sense 4D, thanks for the primer on the subject.
Share this post
Link to post
John I've also seen people build a room around their machine with Plexiglas windows and overhead air cleaner just to filter the air in that small room.  This lets you see what is going on, cuts down on the noise level and helps contain the dust and chips generated.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
About us
Get in touch
Follow us
Recent tweets
Visit us on Facebook
