RustyFN Posted June 23, 2017 Report Share Posted June 23, 2017 I bought eight blocks of wood 6 x 6 x 3. I got two each of four different types. All eight are totally covered in a type of wax. I took a piece of walnut and while turning a bowl I could tell it was very wet. Will they all dry over time with the wax on or do I need to remove it? Quote Link to comment Share on other sites More sharing options...
Gerald Posted June 23, 2017 Report Share Posted June 23, 2017 The wax is a seal to "slow" drying not stop it. If the wood loses moisture too fast it will crack and that is to be avoided. Leave the wax on til you turn it.When you turn if the wood is not completely dry we do what is called a rough turn . For this you leave the woo thickness of 1/10 of the diameter....if the bowl is 10 inches that would be 1 inch.Then use a technique to slow drying until the bowl is dry . Then we do the second turn to finish. This is only a breif explanation of the process and you can fild much longer desertations on the subject of drying wood. If you have more specific questions just ask. You can foind a lot of answers in American Woodturner magazine or the AAW website. Jari 1 Quote Link to comment Share on other sites More sharing options...
Gerald Posted June 23, 2017 Report Share Posted June 23, 2017 Wood Turning Fundamentals is a source for new turners on the AAW site and there is a lot of very good info on turning there . Quote Link to comment Share on other sites More sharing options...
RustyFN Posted June 23, 2017 Author Report Share Posted June 23, 2017 Thanks Gerald. I have seen that on youtube and I did a rough turn. I put the bowl in a brown paper bag and filled it with wood shavings. That seems to be what most people do that I have seen. I wanted to make sure the other blocks would dry with the wax. MEBCWD and Jari 2 Quote Link to comment Share on other sites More sharing options...
Gerald Posted June 23, 2017 Report Share Posted June 23, 2017 Make sure to let the moisture out daily or you will get mold growth. Usually can remove chips after two weeks. A good way to tell stabilization is to weigh at least once every 3-4 days, then when you get the same weight twice is ready. Do not be surprised if the weight goes back up due to humidity changes, that is normal. HARO50, Jari, RustyFN and 1 other 4 Quote Link to comment Share on other sites More sharing options...
RustyFN Posted June 24, 2017 Author Report Share Posted June 24, 2017 I will have to look into a small scale. MEBCWD 1 Quote Link to comment Share on other sites More sharing options...
PostalTom Posted June 24, 2017 Report Share Posted June 24, 2017 1 hour ago, RustyFN said: I will have to look into a small scale Check Harbor Freight. I had the same question a while back, and I think it was Gerald who suggested HF. I was looking on line yesterday, and they had one for around $20 that seemed to fill the bill. MEBCWD 1 Quote Link to comment Share on other sites More sharing options...
RustyFN Posted June 25, 2017 Author Report Share Posted June 25, 2017 I ordered one from Amazon. It was $19. It had great reviews so we will see. I figured it will come in handy when I start to mix resin. Quote Link to comment Share on other sites More sharing options...
PostalTom Posted June 25, 2017 Report Share Posted June 25, 2017 Thanks for the info. I'll keep that in mind when i order mine. Quote Link to comment Share on other sites More sharing options...
HandyDan Posted June 25, 2017 Report Share Posted June 25, 2017 6 hours ago, RustyFN said: I will have to look into a small scale. Got mine at Wally World. Under $20.00 and works great. Quote Link to comment Share on other sites More sharing options...
MEBCWD Posted June 25, 2017 Report Share Posted June 25, 2017 (edited) You can also use a micro wave oven to dry the turning, Pick up a cheap one at a thrift store or garage sale for this use. Don't use the one in the house, some woods really stink when dried like this and your wife will get very very upset, don't ask how I know. You need a scale to tell when the drying is complete. Start by weighing the turning and write down the weight. Heat the turning in the microwave for short periods just enough that it feels warm to the touch, don't get it too hot. Let it cool in the microwave for about 10 minutes, weigh it again and make note of the weight. Repeat this until the weight reading is the same. Some people stop there but I usually heat it one more time. Then clamp it down to a flat surface (use as little clamping pressure as possible to hold it flat to the surface). Leave it there about 30 minutes, this helps it hold it's shape. Then put it back on the lathe and do your final turning and finishing. Don't forget to sign your piece of art! Edited June 25, 2017 by MEBCWD Jari, RustyFN and HARO50 3 Quote Link to comment Share on other sites More sharing options...
