Dadio Posted October 8, 2016 Report Share Posted October 8, 2016 (edited) Here is an interesting concept for spicing 120V wires where a junction box and cover would be unsightly in the final result. http://www.homedepot.com/p/Tyco-Electronics-Romex-Splice-Kit-2-Wire-1-Clam-CPGI-1116377-2/202204326 Herb Edited November 25, 2017 by Ron Dudelston tags added Quote Link to comment Share on other sites More sharing options...
Stick486 Posted October 8, 2016 Report Share Posted October 8, 2016 those are used a lot on double/triple wide trailers... Quote Link to comment Share on other sites More sharing options...
Grandpadave52 Posted October 10, 2016 Report Share Posted October 10, 2016 Interesting...surprisingly our local (small town) HD shows (6) in stock Quote Link to comment Share on other sites More sharing options...
Michael Thuman Posted October 11, 2016 Report Share Posted October 11, 2016 They look to be metal are they if so they must go into an enclosure. If plastic they must still go inside and enclosure per NFPA and NEC standards. Quote Link to comment Share on other sites More sharing options...
Stick486 Posted October 11, 2016 Report Share Posted October 11, 2016 Grandpadave52 1 Quote Link to comment Share on other sites More sharing options...
HandyDan Posted October 11, 2016 Report Share Posted October 11, 2016 (edited) Scroll down to description. Says you can use without box and is NEC compliant Product Overview Tyco Electronic's Non-metallic splice and tap kits provide a fast and reliable method for splicing or tapping 2 wire w/ ground and splicing 3 wire w/ground non-metallic cables up to 300 volts. They are designed and approved for use in rework within existing structures. Splice and Tap Kits also eliminate wire nuts for installation and replace the conventional method for adding a splice or tap for non-metallic cable without the need for exposed and unsightly junction boxes. NEC approved Article 334-40b. 2 Wire Ccnnection For Use On 12 or 14 AWG (300 Volt) 2 wire NM cable with ground Eliminates junction boxes and wire nuts Fast & simple to install NEC compliant - article 334-40b, 2005 & 2008 NEC UL & CSA listed Edited October 11, 2016 by HandyDan Quote Link to comment Share on other sites More sharing options...
Kevin Beitz Posted March 20, 2020 Report Share Posted March 20, 2020 I'm an electrician and I would never use anything like that... Gunny 1 Quote Link to comment Share on other sites More sharing options...
