Showing results for tags 'pin vises'.
I have a soft spot for awls, ice picks and pin vises. Seems I can't pass one up when I see it at a sale. It does have to be reasonably priced though. If the tip needs replaced in a pin vise I found auto brake spring links can be reworked for use as seen in the upper right corned. The end from a long stemmed spring will work too. Get the Dremmel out, cut it to length, chuck it in the drill and sharpen it on the belt sander. For the Exacto knives the sharp end of a big safety pin works well. I like to use it when trying to get the release paper off the double stick tape. I have one ice pick that is new old stock and has a protective cardboard tube still on it. Here is a couple pictures but there are more I didn't gather from the metal shop out back.
