I decided to make a Christmas ornament using wood and acrylic. I wanted to be sure the glue joins held, so I used Wood Fuse. Not sure what else I could count on that would hold good and not show. I carefully lined up the joint on one side and squeezed with my hand. I turned it over as I got a clamp and saw that it was slightly misaligned on the opposite side. It was glued so tight that I couldn't move it at all. Wow.
I clamped it as it was. I think I can make up (cover up) for the alignment. I've used that glue with wood and there is always a grace period of a few minutes. NOT SO WITH WOOD AND ACRYLIC.
